I’d like to start by saying that I spend A LOT of time on here reading through all the threads and yes I have and do use the search function…
I came across 2 particular jobs a few days ago that gave me a really hard time. As you can see in the pictures, I was not successful at removing the stains.
- I DS (hi draw DS Injector) 10% SH from my chem tank, full SH and Elemonator - no water. Let it dwell for 10-15 mins and rinsed. Did that about 3 times without any significant results.
2.Brought out the x-jet, filled a 5 gallon bucket with 3 gallons SH & 2 gallons water and some Elemonator. Let it dwell for 5-10 mins and used a soft brush to do a bit of scrubbing. There was some improvement but nothing significant.
Pump Sprayer - Filled it with half SH half water, sprayed, scrubed with soft brush again, dwell, rinsed. Did that a few times and that’s about as good as it got.
Started to dip my brush in the straight SH chem bucket and doing more scrubbing, not a whole lot of difference.
I also tried a bit of oxalic (my own mix, ran out of f9), I don’t think it made significant difference.
I noticed a few things -
The homes where I did the side and the front, the stucco finish was very porous, I had never dealt with that stucco finish before. Also, they had A LOT of cracks. I also did the balconies of one of them and noticed a ton of cracks on top of the balcony “molding” stucco if that makes sense, and water was definitely getting in there and flushing out (dripping) black stuff from in there. Not sure if this had something to do with it or not. I was able to remove a good amount of black streaks from the front of that one house, but still not enough to make it look good.
This is my first time running into something like this. I do stucco all the time and 9/10 everything comes off just fine with just down streaming (I know that @squidskc always says you can’t DS stucco, but i get really good results most of the time. and I know @Innocentbystander says you should walk away from stucco, but 9/10 homes in my area have stucco so I may as well just close shop all together) .
P.S
Couldn’t use a stiffer brush bc I did a small test spot with it and the paint was coming right off the stucco.
