Better check valve?
For sure, and being that they’re actually foot valves they’ll give him another check valve.
Hook me up. I can’t keep having my bleach diluted like this. I’ll send a pic of my janky setup as well, maybe something else is messed up to cause this.
Will do, I’ll see if I have one left. And sorry I only offer technical support on products that I’ve built :rofl:
Need something inline, the tube/hose goes down through the top of the tank.
This is at the bottom of the tank hooked to the 1/4” chem line……
@Kentucky1234 Got a link?
I made them….DM your address and I’ll send you one tomorrow.
That’s awesome man, I need to measure the hose diameter I’m using first, thanks.
That won’t matter necessarily……it’s a 1/2” npt. You can put a 1/4’, 3/8” or 1/2” Barb on it……as long as it’s a 1/2” threads.
You using a drop stick to keep it on the bottom? You using on your injector or 12V. I have similar but have mine hard piped from top of tank on my 12v, except on truck build, where I’m using a drop stick
Yeah, drop stick….hose goes down through my chem tank, add 18” pvc on ends, I use them for both the ds injector and 12v. They work great…at the end of the season I just pull them out and clean them up, usually not bad though.
y, I 've been using those for like 5-6 years. Work great. Think I got mine from The PWS. They charge like $25 for them.
