Stick with the two nozzle bar until you get to 8gpm. As mentioned above, the nozzles are just impossibly small below that.
Got it. Thank you both for the helpful info.
Jesse
Atlas Services
Exterior Cleaning Specialists
North Carolina
You need at least 2 gpm out of each nozzle, that seems to be the rule of thumb anyway. I have never seen any tips lower than#2ās so even if you wanted to try it, youād be putting out 1100 psi. Iād wait until you get an 8 gpm machine. I was told a 4 nozzle bar wouldnāt work with my 5.5 gpm machine. So I waited until I went to 10 gpms.
How do you like the 10 GPM machine? I have an 8 and have been thinking about buying a used 2 GPM machine and linking them together to test it out.
Let me know how you like it!
Britton Emerson
Emerson Exteriors
10 gpmās is awesome. The only problem is you run out of water damned fast. Had to add a second feed reel. If you re going to connect another machine, you might as well make it 4 gpmās for 12!
Yeah good call, I have 2 feeds in place but only a 125 gallon buffer tank. Might be too small but could be fun!
Are you running 1/2" line all the way from the machine to the gun?
Britton Emerson
Emerson Exteriors
No,l not yet. That is next. It causes a little bypass using 3/8. But rinsing with my ball valve, I get full flow. I plan on using 1/2" from the pump to the first 100 feet of hose. That way I can unhook the last 100 feet for driveways where I need the pressure and full flow. then adding the 100 feet 3/8 when I do house washes and pool deck/enclosures. Where I donāt need the pressure. I can get full flow using my ball valve, which I use 75 % of the time.
Whats the best size SC for a 4gpm machine. Only residential right now so just driveways. I was thinking thr whirl a way 16"
Austin Bischoff
Eco Property Services, LLC
Myrtle Beach , South Carolina.
Pressure Washing & Roof Cleaning
Another Newbie here⦠I first bought me a cleaner from Lowes, it sprays out 3 ways. I like it I do the back and forth then I will go back over do a left to right sweep and it cleans up real good for the money $70. I bought a Northstar at auction house $200 I think 23" it has 2 rubber wheels on the back and rollers up front⦠Does pretty good but I donāt like I really cant go back right to left sweep. You have to turn back and forth. what can make this Northstar do better???
I was wondering out aloud what if I take off the back wheels and front roller wonder if it would sweep ok or be to heavy???
now that is the question of the day
Best at advice I can give us save up and get something like the whisper wash. The time spent trying to make the north star surface cleaner work properly is probably more trouble then itās worth. Once you try out a whisper wash youāll know what I mean.
I second the Whisper Wash Classic.
i wished id passed on this, i like the wand on it. I might put in craigslist⦠Does the whisper have water come out of 3 ways.
I like the water coming out the middle bar⦠Guess I got to get one best price i have seen is $598 so far??? I sure putting alot of money on on stuff I bought a 18ā pole wand last night. I got a job to do at another bank, They got dobber nest all around the dive through top thought that might be goood to have 4 dat.
I wished id passed on this, i like the wand on it. I put in craigslist⦠Does the whisper have water come out of 3 ways.
I like the water coming out the middle bar⦠Guess I got to get one best price i have seen is $598 so far??? I sure putting alot of money on on stuff I bought a 18ā pole wand last night. I got a job to do at another bank, They got dobber nest all around the dive through top thought that might be goood to have 4 dat. This bizzness is pretty good I got 4 jobs to do 2 now and 2 want driveways. They want a shine put on it⦠I read sun has to be at least 75 to use that⦠I been here 60years know a bunch of folks⦠I have to say this is easy pickens so far who got the best Whisper price around???
Thad delete one of them and this, I thought I was reply but put it on Face Book and saw it put on hereā¦
I new to this Face Book stuff dont know all the rules ever where.
I looked for a Edit/delete button but did not find oneā¦
Are they even speaking proper English?
Austin Bischoff
Big Guy, all the way
I found this one made by Whisper a little cheaper than the 2000⦠You cannot use teh 4 nozzle bar on it⦠$499
Whisperwash UC6019HC - Whisper Wash Ultra Clean 19 in. WITH BRUSH Flat Surface Cleaner hover cover
Whisper wash ultra is a cheaper model because it uses cheaper components. the swivel is not the famous green swivel thatās on the classic. It is still a good unit. Itās like the difference between a Gibson Les Paul and an Epiphone Les Paul. (if anyone is familiar with guitars). If you plan on doing a lot of surface cleaning, then you should probably save $100-$150 more for a classic.
Yea Ralph you are prob right only that much moreā¦
Good advice I needed to hear that and will get the Classic
Tks for the reply
Tell me this my 4000 PSI uses a 3/8 fitting and my 2800 uses 1/4" fitting. Can I be changing the fitting on the Classic if I can uses a customers
water???
