Best setup for a 5 ft bed truck
I current have a Dewalt 3400 PSI / 2.5 GPM. Looking for the best surface cleaner for this size PW and any other advice you can provide!
Thanks,
Justin
(post deleted by author)
Justin, you’ll likely not be happy with the answers you are going to get here, but it’s what you need to know. Your current set up is “small” by most standards, especially for doing more than just your house.
I believe the rule of thumb was something around 4” of width for every gallon per minute of machine. So if memory serves me correctly, you could use a 10” rotary surface cleaner. And, that’s if everything in your set up is working correctly with minimal restrictions and/or resistance.
You can certainly wash a few houses with your current washer, but perhaps hold off on the surface cleaning for now. You can always go out and rent a larger machine and surface cleaner if you have the right job(s) lined up to make it worth your while.
Now is a great time of year to be looking at buying other people’s machines that they are parting ways with.
But perhaps you have specifically chosen to run the smaller gpm machine due to water restrictions in your specific market. If that’s the case, you’ll be limited to just the 10” (at max) surface cleaner.
Best of luck to ya whichever way you decide to go!
-Thomas
