I’m new to pressure washing and currently looking for my first machine. There are so many brands, sizes, and setups available that it’s a bit overwhelming trying to decide what to buy.
My goal is to clean driveways, sidewalks, patios, and general residential surfaces, but I also want something reliable that I won’t outgrow too quickly.
What pressure washer would you recommend for someone just starting out? Are there any brands or models that offer good performance and durability without breaking the bank?
I’d appreciate any advice or recommendations from those with experience.
You’ll likely get different answers from different people.
I started with a Honda GX390 motor mated to a 4 gallon-per-minute General Pump (GP4040). It was a direct-drive unit, meaning there were no drive belts or gearboxes to complicate things. At 4gpm, it had enough flow to operate a small surface cleaner (for concrete pool patios and such). Fine for decks, etc. It wasn’t so big that I needed a buffer tank (water reservoir) or anything like that. My first season, it was my only machine and I cleared $100k in gross income.
These 15+ years later, I’ve had many machines but that’s still my favorite power washer. Simple and easy and reliable. I still have it, it runs when needed, and it likely has more than ten thousand hours on it. Here’s a link to today’s equivalent, and I’m amused to see that the price has remained much the same for the past 15 years (I distinctly remember paying $1300). How do they do that? I don’t know. Do basic maintenance, don’t abuse it, and it’ll probably outlast all of us.
My recommendations:
Cleaning for money is generally about flow rate (GPM), not pressure. Measure the output of typical house spigots in your area (use a 5-gallon bucket and a stopwatch to calculate gallons-per-minute). Find a machine which is rated for about the same flow rate as you measure from your local spigots (its no good to pay for a 5.5 gpm machine while trying to run off a 4gpm spigot).
Get a unit with a Honda GX-series motor. GX390 is like the Ford F150… ubiquitous, serviceable, plenty of parts, etc.
Get a pump made by General Pump, Cat, AR, or Comet. Those are “commercial name brands” which should generally last if you take care of them.
Buy a “direct drive” machine. These have the pressure pump bolted straight to the gas motor, without any sort of belt drive etc in between. Those more complicated machines are fine for other situations but as you’re just starting out, I’d recommend getting a simple machine which you can just hook straight to a garden hose and own with the lowest possible maintenance. That’s a direct-drive machine.
Don’t buy a used machine from a local exterior cleaner unless you REALLY trust them. Don’t buy a machine from Home Depot, Lowes, Sherwin Williams, etc. Do buy a chine from Pressure Washer Products, Pressure Washers Direct (now “Ferguson Home”), or - best yet - your local Powerwash supply shop IF they have serious equipment. Where I am, they do not, and so I buy these things online.
I was in the same position not too long ago, and it can definitely feel overwhelming with all the different options. If you’re mainly planning to clean driveways, sidewalks, and patios, I’d lean toward a gas powered unit around 3000 to 3400 PSI with at least 2.5 GPM. That gives you enough power for most residential jobs without feeling limited later on. Community advice often emphasizes that water flow (GPM) matters just as much as PSI for cleaning efficiency.
Brand wise, I’ve heard good things about Simpson, Westinghouse, and Ryobi. They seem to offer a nice balance of performance, reliability, and price, especially if you’re just getting started.
One thing I’d suggest is not spending your entire budget on the machine alone. Save a little for a decent surface cleaner and a quality hose. They’ll make cleaning large areas much faster and easier. Good luck with your first setup!
Professional entry level is largely agreed to be 4 GPM. You typically wont need more than a 3,000 PSI machine as 2,500 PSI is usually sufficient with a post treatment followup. PSI output at the wand or surface cleaner will reduce based on hose size and length. For instance, my 3,000 PSI machine runs an output of 2.4k to 2.5k with 200 ft of 3/8 hose.
Great insights in this thread! I completely agree that 4 GPM is the sweet spot for starting out. Pressure gets all the hype, but water flow (GPM) is what actually saves you hours on driveways and lets a surface cleaner do its job properly.
A Honda GX390 paired with a solid 4 GPM pump is practically bulletproof and easy to maintain. A couple of things that made a huge difference when I was getting started:
Hose length matters: 150–200 ft of 3/8" non-marking hose saves you from constantly dragging the machine around the client’s property.
Chemicals > High Pressure: Pre-treating and post-treating with a soft wash solution removes organic stains much faster than relying purely on high PSI.
I run an exterior cleaning business in Florida and starting with a 4 GPM setup was easily the best choice for efficiency.
Take your time putting the rig together, and good luck with the launch!
Get 4 GPM, they’re completely manageable, but check the weight to make sure you are comfortable picking it up. Measure out distance on Google Earth to see how many feet of hose you need on average. I park at the curb with a 16ft trailer, so I use 200ft PW hose often, sometimes 250ft. If you plan on parking in the driveway, 150ft may be sufficient. Shorter hose is more manageable, especially helpful if you dont have reals. Parking in the driveway with 150ft hose, you should be good to leave the PW in the truck bed most of the time. 200ft would be better. 250ft if you are going to do a lot of large houses or fences with big yards. 2, 100ft 3/8" sections with a 50ft on hand if your budget allows would be good, even if you get a 50ft off Facebook marketplace or something. It sucks coming up short and having to move the whole setup, but it would still be not too bad with a 4 gpm. 100ft water hose if you park in the driveway should be enough, get 3/4" flexzilla. I’ve only used my extra 100ft of water hose from the curb a handful of times and started carrying an extra 15ft hose that bridges the gap almost all the time.
