What is the best 1/4 o rings to use on quick connect?
I’m replacing one a day after about 10 trucks?
Using a Hotsey heated unit. Thanks
Not sure how viton holds up to hot water, but I use the viton o-rings from Pressure Tek on all my quick connects. Can’t remember the last time I changed one…
Viton oringsare cheap and durable. One or two a day is normal with hot water
I use viton after the SH injector.
Before that regular black ones.
Orings are cheap
Yeah. Vinton is the best. Regardless you’ll go through a lot of o rings using hot water and strong chemicals like degreaser and acids. Your best bet is to eliminate as many o rings as possible and just use one long continuous hose
You can find the best O-rings here.
You can find the second best O-rings here.
Lol… u crazy
See, it’s people like you that troll here giving smart alec answers to new guys who are just trying to learn. @Infinity or @Steve can we ban this guy. He has not tact and is disrespectful. Imagine what would happen if someone actually used an onion ring and got hurt because of his suggestion
I’ll send a couple bags of vitons to the first guy who tries it and films it.
look at you go learning to make hyperlinks haha
I googled it for this very reason.
Your half way there to making your own website.
You’re a funny man… i read your post and had to explain to everyone in the room why I spit my beer all over the screen.
I say make calamari out of him, on second thought his wife probably already has that distinction.
