So I want to get into using chemicals to clean concrete/houses and I am looking for a quick and easy chemical mixture that can attack tough stains safely. I have looked into soap mixtures with bleach but am torn between the standard Simple Green soaps with bleach and products like 30 Second Cleaner/ going totally custom and mixing my own pool cleaning chemicals with Dawn Dish soap. I have read so many things that pull me either way. For a guy just starting out with basic equipment, what do you recommend?
I am located in Los Angeles, California btw.
You need to read more than 15 minutes on the search function to get the answers you need. This board is a wealth of information, do a few searches.
Until you figure out what to use by researching here, do your customers a favor a don’t use any of the methods you just listed.
TBH, this means you’ll have to be working with electric equipment and probably can’t even use any of the things you’ve mentioned, lol
There is a wealth of information on this site. When I started out on here I used the search function and found answers to just about everything I needed to know. Type in things like “equipment recommendations”, “down streaming”, “mix ratios” etc.
I guarantee it wasn’t here where you read so many things like that
