This is my first season pressure washing and I’ve begun upgrading my equipment. The first setup I had was a 3300psi/ 2.5gpm ryobi. I’ve used the ryobi SC on all my jobs so far but would like to get another SC for a bigger washer I bought. The new washer is a 4400psi/ 4 gpm. Everything I’ve seen is either max 4000psi or a 5000 psi max but a 6gpm min. Not sure what I need to be looking at. Any help would be much appreciated.
you can change the tips i’m sure to your spec. not sure why a manuf would want to limit their potential and sales to 6gpm.
Get yourself a Whisper Wash 16 from Russ Johnson. I used it with a 4gpm rig and used the nozzles that came with it. Upgraded to a 6.8gpm & just switched nozzles to 2504’s. It’s a great surface cleaner.
