Basic questions
Newbie here. Me and my buddy are starting up our own company to do just on the side for right now. Our set up isn’t the greatest but got to start somewhere right? We will be running a Westinghouse WPX3400 5 Nozzles + Soap Tank Included 3400 PSI 2.6-GPM Cold Water Gas Pressure Washer with 5 Spray Tips and also a Westinghouse PWSC Fits M22 Connections, 15-in up to 3400 PSI Rotating Surface Cleaner. Again I know not the best but doing what we can with what we can afford.
We are looking to do houses, driveways, sidewalks, etc. We will also be cleaning trash cans. We are out of the Louisville, Ky area. Also what are some good chemicals to use? I’ve been reading and keep seeing things about SH. Is that a must? Any and all advice will be appreciated.
Hello and welcome to the forum.
Read more on this forum, a lot more. If you are going into this business and aren’t sure about SH, you need to read more. Trust me (some internet rando) when I say that everything you want to know is probably on this site with the best people to help with questions.
One word of caution, there are many people on here that would tell you not to go into business with a friend. They would tell you that you would be better off giving them half your money and letting them kick you in the junk. That way you will still have a friend/buddy. But you do you.
SH is gold to pressure washers……look up @dcbrock he lives in Louisville! Much success.
The only ship that doesn’t sail is a partnership my friend
@Twotone2025 - as others have said, the easiest way to lose a friend is to go into business with that friend.
Don’t start a pressure washing business with a machine that small
how does one go about making a post here in the newbie section?
When you make a post there’s a place to choose the category. Click on the newbie category.
