That’s awesome do you have any pictures of the 3 100 truck ?
Also are you running the 275s in a truck bed ?
100 gal tank is enough, unless you’re doing large flatwork cleaning
Depends on the houses too. We have a decent # of wells, some of which are lousy. Plus if you run downstream, you’re using the HP gun a lot more per job. We used to have 200 gallon tanks, and decided to go to 275s (plus I had a use for all the old 200s…)
Not really. There’s 4 of them in a row on a flatbed (3 water, 1 SH).
Yeah, they’re on an 8’ skid with a 100 slimline SH tank behind them. Takes up about the front half of the skid.
Them look nice I looked at one on your site that’s the way I think I am going to go.
Where are you getting your 8ft skids at ? Thanks
eh, some fab shop almost up to Delaware…need to find a more local fab guy to make them preferrably…
Yes that’s my think I am in Wisconsin I know there is a local guy for me I am going to ask him.
That’s great makes me think that’s what I am going to do thanks for the update.
I am assuming you used the Jobe valve ?
Topaz valve… 3/4 id garden hose, 1 in tank feed hose
This one…
compact Topaz valve…
It gives more room to navigate drop tube space in the tank, plus easy to remove & clear the filter…
Awsome thank you they are almost same thing much more flow then Hudson float valve as well.
Second on this one…just got tough to find for a while…
Best valve money can buy right there.
Where did you buy that pressure washer from ? Thanks finally getting a new truck this week
