Does anyone have experience with banjo brand flange fittings? I would like to use them to plumb my low pressure lines. I find lots of post about cam lock fittings but not the flange type.
Are they prone to breaking or leaking?
Personally I use the camlock fitting on mine. Banjo vavle on the buffer tank, with a 2in to 1in reducer camlock fitting. Used for about 3 months now, no leaks and easy to take off If i ever need to move it for any reason.
The c clamp flang will give you a much better seal than cam locks . Just more time consuming.
