Any of you running the ball valve and the Mosmatic Swivel? I have the swivel, game changer relative to twisted hoses and I like the idea of the ball valve but that seems like a lot of hardware on the end of a wand. Interested to know other’s experience using the two combined. Thanks
I did read the other posts but I didn’t see where anyone addressed using the two together i.e. fatigue, breakage due to whatever variables etc.
Im using swivels from Northern Tool
There’s a thread on this already with alot of opinion’s/fact’s. I run the ball valve and swivel. I highly recommend that you do the same, it saves time and money.
Mosmatic and ball valve here. I just copied @Racer’s with a little @Innocentbystander twist by leading with the male end.
Racer put up a good video on his ball valve set up. Give it a search. There are a couple good posts on the topic.
I mounted mine directly on my hose. I figure one less o-ring to start leaking.
and less weight
Thanks for the replies. I have the swivel and it’s great. I was just a little put off by the extra steel hanging off the back. The direct to the hose idea seems worth a look too. Thanks for the idea and the replies.
I started using it. Works great! Just need to make sure you seal everything well.
Same. Both of mine are on the end of the hoses.
I went a long time without a ball valve until I burnt myself pretty good with hot water. Now I can’t live without it.
Here’s @Racer video and other comments by folks about ball valves as well.
To ball valve or not to ball valve - #16 by Racer - Supplies & Equipment - Pressure Washing Resource
