Websites that are cheapest to piece together a AR45 or AR30 with an engine? gx160 or gx200? Any recommendations ? And what size hose is best to run with the pump ar45 vs AR30 ? Currently have 200ft of 1/2. Also looking for a skid plate for which ever. Thanks for any advice.
If you want to use the 1/2" AR45 not that efficient. But I’ll let @TexasPressureWashing answer, he’s got all models he uses.
Run AR45 with 5/8” hose. Costs more than AR30 but will last much longer and performs better.
Thought you liked the P40 and 1/2" hose too
Moved up. P40 is good too. Both have minor design things I like.
5/8 for all soft wash systems.
Hi there, which hose brand would you recommend at 5\8?
This one:
