so I just cleaned a concrete patio for a client of mine. It was about 26x26 and took 30 min (including dwell time to clean) then another 30-45 trying to get all the water down the drain. I know i should of brought my shop vac. His HOA patched some cracked portions. The concrete is gray but they patched it with white concrete, it looked horrible. Anyways… he wants me to seal it and I mentioned that they have colored sealers that could hide the ugly patch. He was all about it but when I checked all my usual suppliers, none of them carry colored sealer. I found multiple manufactures online but I always like to ask here first in case some one has any experience. So, anyone ever use a colored sealer? What’s a good brand?
The stuff we use is translucent so if your trying to get a uniform look you have to use a few coats darker the darker color tint the more it hides. Either way in my opinion it’s not great . We get all of our stuff from paver supply warehouse in largo FL and they do ship to California
Transparent stain for concrete will only work for newly poured concrete like patios.
Solid Color stain goes on and covers like a paint and is most likely what you want.
Semi transparent will work the best but only if you put on several coats if the color your matching is dark, and its probably not worth it from a money standpoint.
