i was trying to contact the flo pro guy but he doesn’t respond which is not good business but are there any current discount codes? also their bypass system , does anyone know what all the fittings psi are rated at? I assume at least 4000psi but was trying to figure that out .
Can’t say, I’ve never bought any of those parts from them. If you already have an injector bypass then you just need the system to replace your ball valve… then you toss the old ball valve into the parts box for a spare.
Judd West is the owners name. He’s a great guy, I’ve got one and they are awesome. I’ve never had a problem getting ahold of him. I text or call, no issues. Not sure what the problem is….not like Judd, he has great customer service. His stuff is rated for high pressure……
there is no phone number available on the website. I just see email contact info.
(229) 834-5133
Judd West
I talked to him a minute ago…they are having problems with their email. Just call him.
will do thanks
and any promo codes working ?
The 3/8" valve that’s being used is rated at 3k less if you get the 1/2" version
We finished our own ball valve rated at 5k. It handled close to 8k well ![]()
say what
why would the valve be rated for 3k when systems are putting out 3500 or 4000?
This is the same way I felt! Not only shouldering that liability as a manufacturer but it’s just not right. I’ve seen many MTM Hydro ball valves push the seat out from too much pressure. And besides if you design one from the ground up you don’t have to use 3D printed “adapters”
There is a safety allowance that they are already eating into
You won’t have any problems……unless you are running 5-6k psi…most of us running 3-3500 psi. Been using these bypasses for years….no issues whatsoever. No sense overthinking this….buy the flowpro, you won’t regret it……not sure about any discount codes. I paid I believe 600.00 some years back….best investment.
Still $600, bought 5 of them last year…
Wow….adds up quickly.
