I am submitting a bid on a large housing complex pool deck tonight. It has been requested that we use some cleaner on the concrete. And it is clear that some chemical will end up in the pool.
I just want to be able to say that I am using the best surfactant for the job. Something that will not change the ph of the pool too drastically if possible.
Do you have pictures? They always help. I would start out with hot water if needed put down some house wash mix. Around pools you always need to explain that some runoff is going to get in the pool.
Another company was bidding for the job and said they would use some detergent with a similar ph to that of the pool and the client got it in his head that this would be a better job. He understands some stuff will definitely get into the pool and already talked with the pool maintenance guy.
I am new to this type of work. And I just want to gain some more knowledge for myself and this potential client.
So then, what should i use with my cold water surface cleaner?
