Get a whisper wash classic not the hammerhead
One trick I like is using bottles that messure how much surfactant you putting in your mix because I always lose the little glass measuring cup I got
I e already made the purchase, hopefully this will work to get things going. Thanks for the recommendation.
Most machines come with DS injector. You should be fine.
Top of the line equipment doesn’t make the phone ring. Your order looks good, for the time being don’t do large concrete jobs if the psi is an issue.Good Luck
Who’s Bob? I definitely need better quick connects.
Bob is the owner of www.pressuretek.com one of the top recommended suppliers for pressure washing tools and equipment
