I’m experiencing some really tight space constraints on my skid and the only way I can get my Flowpro to sit where I want it to is by using a 90 Degree fitting to turn the corner on the outlet side to the hose reel.
I’ve got a 10 gallon per minute IGX800 belt drive with a TSF 2221 and 1/2 inch DN15 FlowPro set up.
Any reason I couldn’t run a 45° or 90° half inch stainless steel fitting to a quick connect and run that whip hose to my hose reel.
Everything is half-inch plumbing, except the chemical injector on the Flo pro itself. That is 3/8 inch.
I’m running the gold standard injector and currently pulling 14:1 with a 2.3 mm nozzle.
