It’s extremely light duty 3,000 pound hose. The cover is smooth so it glides easy, it’s not a wrapped hose. I get around 6-8 weeks out of my hoses. You could destroy a hose in a night if you kink it and pull on it. It’s evident how the hose failed so the guys that do this don’t stick around long as I’m not going to be swapping in 3/8" hose for them every time they go out.
          What kind of pressures are you running with it?
The pumps see 2,550 and the gun gets 1,900 on a fresh nozzle. I will slow my engine down a few rpm to reduce a few psi if I get a little tired.
I used to keep a gun on my truck I called the old timer. It runs a worn 1,600 psi tip. I also used it to help nurse along a old unloader until I cared to swap it.
No doubt. I’m a little tired just thinking about doing 88 trucks and 13 trailers in one stint. I’d be tired spraying that many with a garden hose, lol. You need to take up house washing or commercial. You’d think you had retired.
