I switched to 2 wire after getting tired of buying hose. The 2 wire was a tank. Cars ran it over, cuts in it. It eventually got word down to the wire was exposed and still didn’t leak. When it finally went bad the swivel failed, not the hose. I bought some single wire eagle wash to replace it just to see how it goes. Definitely a lot easier dragging around. It’s less then 2 weeks old and has gotten ran over several times. I need to keep some angle iron on the trailer for crossing streets.
I was at an apartment last week and the only place to park was on the opposite side of the parking lot. I kept cringing every time I saw a car run over my pressure hose. I also use 2 wire though. Angle iron might work but I’d worry about it kicking over. It would probably be fine since they aren’t going fast though.
I found these after looking for something later that same evening. Looks like a great option. They’re only about 40" so would probably need 5 of them for a road. Possibly more for a parking lot.
Plug this into the quick connect
Awww. Might be all wobbly, but heck, I’ll try it. So then no need for ball valve right confucius ? @Innocentbystander
There is a need for them. Something has to hold down gas receipts on the desk
Could you share a pic of how you’ve set up your surface cleaner using your gun? I think I know what your saying, but a pic will help alot. Was gonna order a ballvalve too. Your surface cleaner is fed by a 1/4 male right?
That looks like a great option. Thanks for the link
At my cabin with limited coverage. It’s in one of videos here somewhere
Hope you get cabin fever. Lol. Humor, enjoy @Innocentbystander
