Looking at upgrading and have seen a tremendous increase in price on the 5.5/2500psi vs the 5.5/3500psi. Is it worth the money to go with the 3500psi? Looking at $1500 difference. It’ll be used for flat work and house washes.
Thanks for the info
Thanks for the info
Show us what you are comparing
Has to do with stepping up to the larger 630 engine vs the 390, not just the pump im pretty sure
Yea it’s because you’ll have to have a bigger motor for the 5.5 @ 3500. At that price point you should go ahead and get an 8 gpm unit.
I bought the bandit high flow machine from Hotwash Atlanta 3000 psi 5.5 gpm Honda 390 and comet pump for $1728.15 shipped if that helps and I like it.
I’ll check them out. I can swing 1700$ but if it’s not gonna be what I need I might as well wait till I can drop the 3600$.
Is this the one?
http://www.hotwashatlanta.com/pressure-washers-cold-water/cold-water-pressure-washer-5-5-gpm-3000-psi-belt-drive
Yes that’s it
