55 gallon drum
Anyone ever get this from KEC Fungi Guard 15% Sodium Hypochlorite 55g Drum ? If so do they deliver with a lift gate truck?
NO one? Even with shipping it works out to be cheaper (about $10/gallon) and it is almost 3x stronger than Clorox. Clorox is almost $5/ gallon around here.
Most people aren’t buying gallons of clorox. Most everybody gets what they need from a pool supply joint or chemical distributor.
Google “sodium hypochlorite distributors”, “wholesale pool supply” “bulk bleach” and whatever else you can think of and your zip code. Also check Univar and Brenntag.
Thanks, will search what you recommend.
We have 55 gal drums of 12.5% delivered to the shop for $143.10 from a local supplier here in upstate South Carolina. It’s a little higher than some people I’ve heard about, but I’ve never gotten a weak batch and it’s very convenient.
Is that Texize?
No, it’s Socar Chemical over on Rutherford rd. They’re great to deal with.
