5.5 gpm machine
Looking to purchase a new 5.5 gpm belt drive PW for my trailer build. Spring 2025 will be my start into the PW/SW industry. Any advise on what and where to buy would be much appreciated. Thxs. Ron. (U. P. Power Wash)
Probably controversial but might want to find a used unit as a lot of companies upgrade to an 8gpm eventually.
Frankly you may just want to spring for the 8 anyway, it’s a real time saver on driveways and a beast when rinsing.
Thxs!! I was thinking the same.
Can anyone see what I did wrong? I have power but the strobe light and ball valve do not come on when I hit the on button on the remote.
If I’m tracing the wires correctly, that looks right.
Dumb stuff out of the way first.
Batteries in the remote?
You paired the remote and control box?
You turned it on via the push button on the box?
I don’t know how to pair them. I thought they came paired. Is it possible that I have the 110v receiver and not the 12v? I’m seeing now they make a 110v and going back on my orders it looks like I ordered the 110v.
It should have a button on the side, if I recall correctly you push it 3 times, then the A followed by B on the remote. Try that, but the wrong voltage is probably the issue.
I tried pairing and got nothing. The green light on the side of receiver is supposed to come on and mine never did. I guess I buy the 12v receiver and see if that works. Thxs!
Looks like an ac receiver and you want 12v dc
Thxs!
