Hey guys finally had time to take a few pics of my trailer and set up. I know it’s pretty basic but it’s been a great money maker so far. So much of your guys help went into building it. I can’t thank you guys enough. Feel free to put it on blast. One thing I wish I would have done is to put the reels on the other side of the trailer.
The PW is a gx390 with an udor gear 5.5 pump. I found the little fishing box on Amazon and labeled all the nozzles with their psi.
Did you swap over the pump on your own? I may be doing that soon with the gear drive to run a buffer.
Nice setup though, but if you have some down time swap the reels over, definitely worth the time.
I’m getting about 2900 from the gun. I have one more year until I graduate, May of 2020. Thankfully I made some good money pwing this year I can afford to only work weekends at my regular job during the last two semesters. Will be an intense last year but I’m looking forward to learning emergency and critical care. It will be perfect once I graduate only working a couple 12s and pwing. Hope all is well!
