@Infinity
If someone is using a smaller orifice injector(to increase draw rate), is it possible that it would restrict flow enough, to where psi will drop as well? Assuming the injector stays on the line while the SC is being used…
Yes, I believe that would result in a pressure drop. I was bypassing my injector when I did my pressure test.
