Sorry I’m aware I should search around and work it out myself which ive tried. I want to know the dilution of my 4:1 xjet @ 21/LPM 5k PSI machine pulling from straight 12.5% SH would be. Maths is my weak suit.
Thanks In advance
Thanks In advance
Do a bucket test and find out.
First fill up a container with set amount of water which will be your SH. Put lines on it for every ounce, ml, or whichever measurement you’re use to using. Then start to fill up a 5 gallon bucket of water and time it. You’ll then know how much the xjet siphoned out of the container.
We want to know who you are and what you do, we can’t be just handing out top secret information to anybody on here.
I’m not sure what a 4:1 XJet is but if it’s pulling 4 parts water to 1 part chem that’s 5.25 lpm of chemical.
