I’m using a 55 gal rain barrel with a 1 inch ball valve and plan on reducing to Clear Vinyl Tubing, 3/4 inch to a 3/4 strainer then to more tubing then finally to pressure washer.
Long story short am I limiting my flow to my washer by reducing to 3/4 hose and not just using 1 inch tubing with a 3/4 reducer to the pressure washer. Or would will I be fine and not effect it much with the change in diameter and get enough water regardless of 1 inch or 3/4.
