I built a new trailer out of a standard 7 x 16 Tandem Axle Utility Trailer at the start of this year and realized that I hadn’t shared with you guys yet. I’d be glad to answer any questions about it… it’s been really good so far… really efficient.! For some reason I can’t get the order of these pictures correct so I apologize in advance.
.!Looks Great!! Could you give an estimate of around how much to recreate this or something similar? already have a trailer i plan on re decking soon. trying to decide if its worth it to build one or buy a northstar setup
Don’t go Northstar. There are plenty of guys on here to advise on what machine. I have a Northstar set up I purchased new last year before I read up enough to make an educated purchase. I have it, it works but if I could do it over again I would’ve read a lot more and made a better setup.
What type of Northstar machine did you buy? Just curious. I bought one myself but did some modifying. It’s my little sleeper now😎 @PWP5gpm
5gpm belt drive with honda 390. It’s not terrible but I don’t use it daily either it’s a licensed side hustle for now.
Looks great!!!,should have made the wood boards look like a deck that you stain and clean
Wood floors get too torn up to put a lot of time into them to make them pretty.
In just equipment & materials I think it was about $15k. I have it tallied up somewhere. This is assuming you doing all the work yourself of course.
