Alright, guys with hot water experience, I’m upgrading to an 8GPM hot water machine from KEC or Pressure tek within the next 2 weeks and need to know what are the pros and cons to the burner types. Seems to be about a $500 difference in price (115v being more) but I’m not experienced enough to know what’s better and why. Any help is greatly appreciated.
Britton Emerson
Victoria BC Canada
Emerson Exteriors O/O
The 110v PW’s have a generator on them with an extra outlet or two which you can use for lights etc. Also a 12v system, if the battery loses just a little of it’s charging level during usage or it’s just not charge enough, the burner will not run correctly. Been there and done that and I swore off 12v burners because I can’t afford to have a job not work out right.
For the extra $500 it’s most definitely worth it to have a hot water 110v PW.
Oh right. Duh! Thanx Tim. I’m too caught up in the big purchase and getting scatter brained. What about engine size while were on it. They have GX 630 or GX 690’s and 3000 or 3500 psi. I think I’m sold on the GX690 and 3500 PSI unless you guys suggest other wise
Britton Emerson
Victoria BC Canada
Emerson Exteriors O/O emersonexteriors.com (name change so it’s under construction)
250-883-6067
If it was me I would go with the 3500psi PW because we run hundreds of ft of hose and you basically lose about 1 psi per foot when running long distance of hoses.
