Just wanted to share my build on a 12’ open trailer. I decided to mount the pressure washer on the back of the trailer for easy access. I currently have a 4 GPM, but will be adding an 8 GPM to the other side. A long way to go, but it will usable soon if I can get time to finish it.
Make sure you’re keeping at least 10% of the entire weight of the trailer on the tongue. It’s one of the reasons most people put the machine up there. If you don’t have 10% on the tongue, you’ll hurt yourself and others.
Thanks. My SH tank, soft wash & tool box will be in the front.
Right on. Looks good, I like the rack and the reels base.
Great start!
Thanks!
Looks like we are neighbors! LOL
Did have a channel from the front to the top rail on 45 degrees? I thought about removing it for a tool box or spare tire mount.
Where are you located ? Also I removed the 45 degree front bar for a toolbox
I am in New Orleans. Who Dat!
I like the effort your putting in . Little tip for your next build, cut your steel at 45 degrees, less cutting, less welding, less distortion.
To heck with the wash trailer, show us some pics of that big boat next to it.
That’s a sweet unit. You get to use it much?
Garmin, twin 4strokes and outriggers. I like you!
LOL, I’ll trade you a 14’ trailer loaded with equipment for it.
Not as much as I would like. But can’t complain.
