You might. I would try DS’ing straight 12.5 and see. But if all else fails, the pump up might be your best bet. Good luck.
Yep, what all the others said. When I said 50-50, that’s applying direct, with a 12v or a pump up. Couple of applications applying direct, let dwell about 10min in between and you should be good to go or darn close.
You can try several applications of straight SH downstreaming, may or may not work.
I got home too late and it’s dark tonight but I saw the chimney this morning. It’s not clean but looks much better dry. Those last pics were after rinsing in the dark. I’ll try and post one tomorrow if I can.
So has anyone tried steam to remove vine tendrils on brick? Do you guys think that could work together with brushing with a hard bristled brush?
Most folks here are washing contractors. Probably not going to find an answer. Reviving vines has nothing to do with washing
