I havent had a birdnest either and the thing you an I have in common is we have quality hannay reels. Maybe cheaper reels don’t have as good of braking systems. Also having electric reels helps with reducing free spin.
Only hannay reels here. No electric, well, I have one that is torn apart and sitting in my garage. At least the parts are repainted.
I have electric too, no problems….
Maybe that’s the problem, the ‘lock’ on the Titan reel bends just looking at it. Do you guys set the brake resistance high or something? I set mine to freewheel so I’m not pulling my shoulder out of socket.
When i had manual Hannays i’d set it to the sweet spot where it wouldn’t birdsnest and it wasn’t too hard to pull off. Next time you go to buy a reel try out a Hanney 1500. Money well spent.
Gotcha, maybe I’ll try cranking the brake screws down some next time. I guess it’s similar to a bait cast reel.
Now THAT is something I can birds nest nearly every single time. Spinning reels only for me.
As far as I know, the electric Hannays do not have a Brake nor a lock
No experience with electric reels but some DC motors have a mechanical brake that can only be disengaged when voltage is applied. I wouldn’t be surprised if all the guys that don’t have bird nesting issues are using flow unloaders. They gradually introduce pressure & eliminate that sudden burst.
Good point, I’m still using the trapped unloader that came with the unit. You guys and your fancy equipment.![]()
It’s real elegant stuff. I ordered mine from Victoria Secret and it was delivered on a fuzzy red pillow.
I had birds nests if I didn’t lock my reel with the trapped unloader. I run 250 ft of hose straight into reel so I usually have hose left on reel. I switched over to a flow unloader and now if I forget to lock it, it loosens up. no more mess.
