Hi! I followed a link, while reading about what an xjet is (I’ll downstream), to this thread and I am happy I did.
The pic of you washing a skyscraper from the ground made me see light at the end of a ladder filled tunnel.
I’m interested to know if this tip is compatible/effective with a 4GPM 4K machine? I would much rather buy a tip instead of trying to swing a 18 -24’ telescoping rod around.
Guy isn’t in here much. I have about 50 entries in my phone under “guy” and “cat”. I can never find the number for that cat who sells me hose or the guy who washes my house. Anyway, text Guy Blackmon and he’ll get you a nozzle
I have a brass version. Word of caution, don’t let the hole get nicked or dinged by dropping it on the ground. Mine started misting a bit, ended up grinding the tip flat again. There’s a reason why rifle barrels have a crown.
Is this what you are referring to? This is my gun, and I have my j-rod on it. Would I not benefit from having an assassin tip in my jrod as well? Thanks IBS
It only takes about 5 inches to straighten a stream of water. The nipple does the same thing as a shooter tip. Put a quick connect on the outlet of the gun and you can plug your sorry wand in, or just a nozzle, or s long want if you need it. I don’t use any wand, and rarely a nozzle on single story buildings or in breezeways
