I love my general pump 20” hammerhead with 4 gpm. Check it out
I think I will like it even better once I upgrade to the 8 gpm!
Pretty good. Post treat would help.
I’m still new and learning. I see a lot of guys have a 5.5 GPM belt drive. Would you go 16 or 20 inch with that flowrate?
I would get a 19" Whisper Wash
Are you still happy with the Hammerhead 20"? I also have a 4gpm/4k PW and debating between this and the whisper wash 16".
No. I did not like the hammerhead. It’s pretty cheap. Others have had them for a good bit but with a 4 gpm after only 2 months the swivel locked up under pressure and the only way to get it to spin was to open up the swivel and lubricate it a bunch. Which after a week of light use would bind up again.
I ended up literally tossing the whole unit into a dumpster and purchased a whisper wash which I should have done from the start. Their swivels are the best, one of the best, I haven’t ventured into mosmatic surface cleaners but for the price, whisper wash is the best and I would go with them. Never had to mess with their swivel. Plus their aluminum bar is better vs the skinny bar on the hammerhead. I use my whisper wash with a 8.5 unit with 200 degree heat consistently and it’s never failed me so far
Okay, good to know thanks!
