How did you find the contact information for all those property managers? I work consistently with 2 apartment complexes but would definitely like to get more. Condos/apartments is good money?
Google… LinkedIn…Google
Not sure how far you travel, other then Athens it looks like not much for Condos. Do you Target west Atlanta or Alpherreta? Alpherreta would be a gold mine for Condos.
Yes, we travel to most of NE Ga. Alpharetta is only about an hour from Athens. I will check out those listing, thanks for the info!
How about Home Advisor?? I keep getting calls from this girl to sign up??? is that worth anything?
How do you unscrew the end? I tried doing that early on, but I could not get the black end off.
With the nozzle pointed at my face, which way do I turn the black tip?
You have to heat it a bit with a propane torch. Manufacturers put on a special sealant.
