@anon26752184
Apologies, I was at work and didn’t have much time. I figured others would come on correct what was wrong.
Let’s go one by one
pretreatment of SH onto a dry porous surface, which has organic growth on it won’t run-off into the drain.
If there is runoff into a drain, it will have SH.
“It’s super absorbent, it soaks right in. Deep.”
No deeper than water, and not as deep as all the mold lives. The chemical nature of SH means it can’t get deep enough on a porous surface to actually kill all the mold.
“The heat makes SH dissipate much faster.”
You didn’t quantify you were pre-wetting a scorching surface. However, let’s say you were. Heat increases the chemical reaction that turns SH into salt and water, but it’s not an instantaneous thing. Again, if there is runoff it will have SH
“The actual SH oxidises the mould and the potency is dramatically reduced due to this chemical reaction.
False. If you were to oxidize mold it would cause it to grow, not die. SH kills mold by attacking the cells, it also has a pH that is really unsuitable for life…which is why vinegar also kills mold. (It’s actually a diluted form of glacial acetic acid)
you’re not washing 12.5% SH down the drain.
That I can agree with…then again it wasn’t 12.5% the minute you put it in the water stream. It’s still enough to have the pH be too high for a discharge into the drain.
I am well liked (okay maybe except the wall thread, lol!) because I’m a straight shooter. I don’t sugar coat things and I use plain English to explain complex chemical processes. I have been employed as a chemist for over 20 years. So when I say
“WHAT!!! WHAT!!!
NOOOOOOOOOOOOOOOOOOOOOOOO
Please don’t spread that information to newbies.”
I mean; what, what, nooooooo; as in, you are wrong. There are certain chemical processes that can be explained in a rudimentary way, but thinking that somehow all the SH just went poof would be incorrect. If you don’t believe me, capture the runoff, then have someone who doesn’t smell SH all day take a whiff. They will say it smells like bleach.
Is it 12.5%, no. It’s still not okay to go down a drain.
