Cool, thanks guys. I spent way too much time going back to the machine to disconnect ds on my first couple jobs. Just the start of many learning experiences im sure of it. Plan to try jrod and also bypass kit or small shut off valve for ds hose. If it’s too much pressure with the j-rod can you choke down the ball valve to get less pressure or does that take away too much flow🤔
It will take away flow.
As you gain experience (and possibly upgrade to a larger machine) you will be able to soap larger areas at a time, and not need to run back and forth so much.
On a small 1500-2000 sq ft ranch, I usually only need to soap in two sections, washing two sides at a time. So that’s only about 3 or 4 walks back to the trailer.
