Pedator 459 vs. DuroMax 500, DIY GR build?
Someone please educate me. I have done many concrete recoatings for swimming pool decks. 90% of the time its brushed concrete. Most manufactures recommend 3100 psi to open the pores of the concrete when either acid etching or surface cleaning before material application. Is it not the same principle when removing oil stains or organics that have penetrated the concrete? Are the chemicals this difference maker for the lower psi needed?
