Some people like yourself seem not to like good advice when it’s given. Doing research is the best way to learn what you need to know while gathering other valuable information for your business. I can tell by the way you approached this job and by the proof that your profile shows that you have not done anywhere close to 60 hours of research. Say what you will but I believe I did try to help you learn what you need to know to do a job like this properly without spoon feeding. When you are simply told the information you aren’t learning everything you need to know and it doesn’t stick nearly as well.
