Gotcha what did the milky water look like when it dried? Did it leave a residue
It was still wet when we left so I donāt really know
With a foamer
I use straight 12.5 and only get about .8% out the nozzle.
As a window cleaner, I see this all the time with junky vinyl windows. The paint just runs down onto the glass when surfactant is used.
Thats hardly a āhotā mix for stucco. I hit stucco with 3% most of the time. 4% sometimes
Yeah. sometimes it just happens nothing to worry about. collect your money and do another one
You are right itās not for stucco but he is not just doing stucco
Link to the former you use
So he used 12.5 straight through an injector. Thatās hardly too hot by most standards and usually not even effective for stucco in my area. Whatās the issue you have with his mix? Heās applying 1.2% max as far as I can tell. Thatās what a lot of people are suing with perfect results
I generally use 2 to 3 percent on stucco depending on how bad it is
Sorry.
Long day.
Oh I know, thereās been a handful of stucco jobs I turned down because I knew my mix wasnāt going to be strong enough. Working on setting up 12v.
Cheap paint. Since itās white it will probably look fine.
By the way I ds straight 12.5 on my 8gpm. I would mix 2 gallons water to 3 gallons 12.5 with my 5.5 when I had it hooked up.
Exactly, my mix is hardly strong enough for stucco. Works very well if its just light green algae, which is the bulk of the work that we do. Itās hotter than a lot of the guys here have in their house wash tank because a lot of them are just doing a ton of vinyl, which is a little overkill if youāre just doing a bunch of vinyl.
You got an iphone? Going to send you a movie if you do. Sht video of me cleaning 3 year old SW paint off a house that had failed. You didnāt do anything wrong
Iām not saying you did anything wrong. I was taught that its always better to start light and go stronger if you need to no reason to use chemical you have to is all I was getting at. But you do what works for you
Same, send me one when you get a chance. Iāve been looking for one for degreaser anyways.
it is lafferty
got 2
one for my 4gpm and one for my 8gpm
I know that pressurewashoutlet has them, did not buy it from them but from laffarty
but cannt find my invoice how much I paid for them.
But I think it was aroud $120 each
Almost every single house. In my area is heavily oxidized siding. We simply just wash and do everything. Possible to reduce pressure and direct streams hitting the surfacd
Gentlemen I would like to apologize to whoever found one of my post offensive and flagged it. I hope I made the necessary changes. Forgive me Iām still new at this forum thing
