You’re lucky. If I shut the machine off with pressure still in the line, it won’t start.
The ZK1 is a heckuva good luck charm.
I’m unsure which unloader I’ve got as part of this set up. I wonder if I could add a pressure relief valve in the spot where the pressure gauge blew off. Would that work?
I panicked when I saw the pressure gauge shear it’s thread and fly into the air. Water was jetting everywhere… so I closed the main valve for a bit and then pressed the emergency stop button. Haven’t started it since. Joined this forum. It’s been very helpful. Thanks.
Same here, except I only run at 1/2 throttle about 30 sec before wide open
Yep. The difference in pressure between the unloader block and the nozzle can be dramatic.
