Help with roof wash
I thought so……you figured it out. Fix that and go back and try again, no worries.
Once you have you water pulling the same leave it set there. Just adjust your sh, you should be good then.
What surfactant are you using?
Roof Snot from Southside.
If it’s brown it’s coming down, if it’s black you’re going back.
Yeah hard to tell what color it is by the pic. I’ll see what happens after the rain this weekend.
I like the way you think :grin:
Just play with your buckets and dial in 3-5%. The vast majority I do at 3-4%. 3% if fresh will clean most of the roof. With the price of SH what it is, better to have to hit a couple of sections a little more than shoot 5% on the entire roof. That one not even that dirty. 4% would have gotten easily. Most of mine similar to @Kentucky1234 .
Did it turn brown-ish when you applied? I tell my guys “once it’s brown it’s coming down”. Sometimes you have to apply a couple of times.
It was a cloudy day, I honestly couldn’t tell. Apparently even though I had my SH valve full open, it was only drawing a 1:2 ratio and coupled with weak November bleach it didn’t do much.
