For some of us yes.
I use that for each 5 gallon of mix.
I saw someone recommend .5 to 1 oz per 1 gallon of mix to DS 10:1 and it has worked well for me. There is a light amount of suds that come out and windows still dry streak free. I’ll test out .5 oz to 1 gallon and DS that 10:1 and see how it is.
half an oz works just as well. Its hard to notice a difference in suds so, ill continue to use .5 oz of elemonator per gal of mix which i DS 10:1
From 1978 to 1984 I sold Amway products. I learned a lot about myself, my attitude, my service to others in life and their great products. Their LOC (Liquid Organic Cleaner) is a surfactant recommended for many uses, industrial, residential, agri and automotive. Perhaps this will help your search.
Lol, someone here old enough to remember Scamway.
hey so i am just starting out softwashing (well testing i should say, will be using a battery powered sprayer). so i live in a country far far away from anyone selling surfuctants, but luckily i have a chemical shop in my neighborhood.
i will mainly be applying my softwash to walls which are render or stucco and are painted. and since these houses are all attached to eachother i would need something that masks the smell of SH.
3 questions for you.
1)how would i know if a fragrance will work in LO and SH?
what is the % the LO should be diluted to in the bleach?
what can i add to make it sticky? since all the walls are flat i would love something which can make it stick on better
thanks so much for your time !
Hi,
The fragrance houses will have bleach stable fragrances. But you have to ask for them specifically.
Look up the dosage for items like Elemonator and SLO-mo. They will have the correct dosage for LO vs SH.
It isn’t sticky so much as it is thicker. You will have to play with your blends or ask around.
I’ve never pressure washed anything in my life, I’m just a lab geek at a chemical company, or I was until I moved into regulatory full time.
Good luck!
