We uses a10 gallon sprayer and a 1.4@100 psi 12 volt pump. Works well with any sealer I’ve used even cheap Thompson wood sealer
Thanks for sharing, I have never been game to run dealer thru my airless setups I’m going to have to give the 12v a crack and see how it goes!
Any suggestions on tip/nozzle type ? I guess size of tip varies with viscosity of sealer and fan width needed?
Sealer not dealer lol
I use 100ft 3/8 hose with a poly gun. Tip is 60degree #12 orfice . It’s worked good on all sealers so far. It’s a nice even spray pattern
Awesome thanks heaps u may have just saved me a lot of time!
Anytime buddy
Sealer doesn’t seize your pump or clog anything up? I remember doing that with a 4 or 5 gal pump up and hated life lol.
Fill it back up with water and a small box of baking soda through it when you done and it will be fine
Do you let it sit like that or rinse it out with water and baking soda? Is that for water based sealers?
Rince it out . I fill the tank back up with water then pour in the box of baking soda mit it really well the pump it through like your spraying sealer until the tank is empty. I’ve only had to replace one pump over the last few years. I’m not huge on sealer probably less than 20 jobs a year but it’s worked fine. Biggest problem is Cleaning out the tank so the pump doesn’t get clogged the sealer leave a paper thin coat that every now and then will peal off the inside of the tank
90 percent water based sealer . Solvent based sealer is not for my humid climate.
Ok I’ll have to give it a try, I’ve been wanting to use a tank and 12v setup just couldn’t figure out what would clean the system best. Thanks.
What reel is that?
Also, what size is that tank?
I have a mix of titan and hannay reels . The tanks are 2x225 buffer 1 225 tank for SH AND 1 50gallon for OX
If you meant the sealer cart . It’s a cheep NT 10 gallon tank and a cheep harbor freight hose reel with 100’ of cheep 3/8 braided hose. . Don’t spend to much on anything. The sealer will eventually make you replace it
Yep, meant the sealer cart. Thanks.
