@amateur
@Bdiamonds
The unloaders I use are MTM hydro, I’ll have to look at the part number tomorrow. They are $65 @ my local dealer. Only had one issue with one of them and my dealer just handed me a new one. Lol.
I’ll be waiting to see your pics!
Usually the only time someone give you a hard time around here is if you ask questions without doing any research. (Or if you mention a WALL
@squidskc.
Good info- package was re routed and is now projected to Be here today—smh
Hey when you mention the blue spring unloader, is it this one:
https://www.generalpumponline.com/product/gp-pulsar4hp-trapped-pressure-unloader-10-5-gpm-4050-psi/
Or this one?
https://www.generalpumponline.com/product/gp-yub21405-trapped-pressure-unloader-21-gpm-4500-psi/
The first one is way cheaper but I’ve seen sometimes it comes with the cap on it which I know usually means garbage! The second one is rated for much higher flow and had 1/2” bypass port.
I use the second one. It might be Overkill but they seem to last longer
