BACK ORDERED Remote downstream controller (The Schertz Box)
https://www.schertzbox.com/
@shawn1 you can find replacement remotes on the site.
Yes I saw that one. Looking for other remotes
How come?
You should be able to program other remotes to a certain extent. At least I’ve programmed a remote from a different receiver and vice versa.
It depends on the frequency of the remote. It’s a shot in the dark. I will also say the big original remote has the best range.
Hey if I was to shorten the drop tube that goes into the mix bucket would that increase the ratio to pull more soap? Should the inlet and outlets be the same length? Just want to pull the most soap possible. Also, if I put my mix tank up higher would gravity help pull more also?
No
It doesn’t make any difference
No
I can’t see it having any difference. Unless it was a 30-40 foot run to a tank. I had 15 foot once and pulled fine. If you aren’t using gp high draws stepped down a size I would encourage you to try!
Just got 2 new ones. 5-8 and 3-5.
That seems high.
What does?
I’ve forgotten! :crazy_face:
Thanks @SchertzServicesLLC !
Best investment I’ve ever made.
:rofl::rofl::rofl::rofl::rofl:
What’s funny there @DisplacedTexan , I wanna know !
Oh, nothing. Glad you got yourself a Schertzbox. They’re super handy to have :+1:
I’ve got a couple of them. Much much better than my own design and well worth the money
Am I correct is assuming that:
  1. The injector bypass is no longer necessary with the schertz box?
  2. All flow (whether soap or straight water) will pass through the chem injector?
I’ve thumbed through this thread but it’s crazy long so if it’s been talked about before, sorry.
  1. It’s never necessary
  2. Yes
