I send you an invoice that can be paid by credit or debit. I do not know an approximate date. I hope within 2 weeks I can have some free time.
How much are they?
$375 for the single way valve and $425 for the 3 way.
3 way sends water to the injector when you turn the soap off with the remote. 2 way just stops the soap.
I definitely want to buy one so let me know when you have a better idea of a time frame.
Did you have a different setup before?
Itās something I threw together. Basically a valve hanging on the wall inline on the ds draw line. Nothing fancy but it worked. I lost gpm due to not drawing water when off. I never flushed so the valve went bad in 4 months. I never replaced it because I wanted the extra flow for rinsing.
Iām on day 3 with mine, but Iāve got it set up to pull water when soap is off. I couldnāt be happier. I flush the soap valve with water after every job so Iām hoping I can get a year out of it, but if not itāll be worth it to swap every 4 months.
@SchertzServicesLLC sounds like a great product you built!
Canāt wait to hear some more reviewsā¦
You should look into opening an online store, word travels quick in this industry
What valves did you use?
I could pretty easily add a tab to my website for it. But right now I want to make sure itās perfect before I large scale anything. I think itās perfect but Iām biased.
The next batch I build I will likely build a couple extra of each setup. Then I can ship right away.
The biggest problem has been a 3/4 inch mpt to 1/4 barb 90 degree. Itās a 90Ā¢ part but everywhere I have found them are back ordered.
Last order of them I put in was for 40 so I have tons of spares.
Iām sure youāll get your moneys worth. Theyāre solid valves from my experience abusing them.
Threaten them with pics of your cat, youāll probably get 80 units. (Big chief no hair, of the no meow,meow tribe)
$27.99
The 3/4ā one is only $37. Iām tempted to try it on my inlet hose to cut off flow instead of the Hudson valves which I have awful luck with.
Oh and if anyone knows how to remote start the gx690ās and can show me the wiring thatād be awesome. Lol
I bet a really cheap remote car starter could do the trick
Just out of curiosity. Whatās the purpose of remote starting the engine?
Just to be fancy.
plus one
I can scoot my truck up without a driver is that fancy???
Still need to see about that truck mounted microwave tho
https://green-leaf.us/product/elbow-adapter-34-mpt-14-barb/
Have you tried directly from the manufacturer?
