I use it when doing large flat work jobs it work great. Ive never tried it on what your probably considering stucco but I can tell you this . When I pre and post treat concrete with it . No matter how dirty or nasty it is I never have to come back and spray 50/50 on it . It’s a little stronger than 1 percent
My spare 12vs just got delivered. I have a few jobs in line I’d like to try this on. I bought a 2gpm and a 5gpm. I don’t anticipate much of a difference in terms of strength from the two when force feeding. Do you think it matters or will the 5gpm achieve a stronger mix?
2 gpm will be fine
I’m guessing a 5gpm pump would cycle like mad if you try to use it to force feed an injector.
Pretty much. We use a 5.5@60 for feeding two injectors. It still cycles a lot
Just realized the 2gpm pump I ordered has 3/8 barbs, no fpt like the bigger pumps. I ordered the 3/8mpt to 1/4” male barb. Gonna have to order a 3/8 to 1/4 barb reducer. More waiting. Luckily zoro is pretty quick.
