Do you have a link? KEC is really hard to navigate. Especially on a mobile device
Here you go. Tell 'em I sent you. I’m hoping Jason puts me on their payroll soon, lol!
I would suggest buying a machine from a local dealer. When you have service issues you’ll appreciate having bought local. I found the best deal I could on line and went to the local guy and he matched the price. Now, since I’m his customer, when I have an issue is can get it fixed in a matter of hours, not days.
Yay. The ramp slipped and I dropped it on it’s side in my driveway. Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.
Extreme newb here. I can use the customers waterline to feed the 5.6@2500psi unit linked here? Im currently using the B and S Powerflow unit and it seems to only work well with the provided 25ft hose. Looking to upgrade. I work out of my pickup at the moment and have no tanks.
TIA
5.5 GPM is generally on the border of needing a buffer tank, or feeding from the spigot. Obviously you can feed from the spigot if the flow is good enough… whether or not the flow is good enough depends on several variables.
Safer, and less of a headache to use a buffer tank. Doesn’t have to be huge… a 55 gallon drum will work.
What he said ^^^^
