Steps of full service for a solo guy
Just wondering what the steps are when doing a house wash with patio and concrete/driveway etc.
My current “route” is wash and rinse house, then deck, then concrete/surface cleaner stuff.
Is there a more efficient way to go for a solo op? Thanks.
Seems like you got it down to me. I guess you could try starting at the driveway since you get to that first when you pull up. Just clean as you go in, once you get set up of course, but from my experience just go non stop no breaks. Its the fastest way other than getting more efficient equipment.
You’re doing perfect. I like to wash my way off a property, just like if you were painting a floor in a room with only one door. It doesn’t make a lot of sense to wash drive first and then be walking back and forth on it, dragging hoses and loose grass etc on it. then you’ll have to rinse again.
I start in the furthest corner of the house, and work my way to the front. That way all my equipment is now in the front ready to be packed up.
The only time i really change this is due to weather complications
